603,348 active members*
2,435 visitors online*
Results 1 to 5 of 5
    Feb 2006
    13
    Corrupted Data
    while attempting to install the engraving demo available on the Ajax website I accidentally corrupted my data. I unknowingly had the backup program for a router that I had worked on previously on the thumb drive.
    My question is does anyone know whether or not if I download the latest version of the control software from the Ajax websitewill it over right my existing data and get me back to square one? And at that point will unlock codes still work.
    Dan
    Feb 2008
    280
    If what you installed was Report files from the other machine (made with F7/Utility, F7/Report) then reinstalling control software, or installing a control software update, will not help.
    A Report backs up and restores your machine-specific files (configuration, parameters, tool and job setup, PLC programming, etc.).
    A software update deliberately avoids replacing any of those files.
    You need an earlier Report from the machine in question. If you don't have one, you are stuck re-entering all your configuration and parameter information (starting with your software unlock codes).
    Feb 2006
    13
    corrupted data
    Thanks for the clarification on exactly what is backed up in the report file.
    I had a knowledgeable linux friend over last night we discovered that I had put a pereod In the wrong place while trying to correct my M code section. Everything is working great now.
    Dan
    Dec 2008
    44
    Quote Originally Posted by dandonegan View Post
    Dan
    Dan,
    Glad to hear it. I assume you got the probe working as well?
    Regards
    Scott
    Feb 2006
    13
    yes everything is working perfectly now. Scott I appreciate all your help as well as the help of the group.
    Dan
  1. Partner Lathe "Parameter File Corrupted"
    By Joe Miranda in forum Milltronics
    Last Post: 09-03-2011, 03:25 AM
  2. f-hole data anyone?
    By eurospruce in forum Musical Instrument Design and Construction
    Last Post: 10-17-2010, 06:53 PM
  3. IKEGAI 0TB PMC PROGRAM CORRUPTED.
    By GPena in forum Fanuc
    Last Post: 05-13-2008, 07:39 PM
  4. BCC v22 Speed/Feeds corrupted if file saved without post
    By brooklynmetal in forum BobCad-Cam
    Last Post: 03-25-2008, 02:33 PM
  5. series 1 nc, memory corrupted?
    By tpretto in forum Bridgeport / Hardinge Mills
    Last Post: 10-04-2006, 02:31 PM
