Here is a copy of posts on the plasmacam owners help forum.
I had a new computer with windows 7 built for my table. I had the lava 5v Parallel PCI/LP port installed. When I try to initialize my table I get "Could not start port access driver error code :2". Can someone help me with this?
Kerry
Either you are not logged in to Windows with an administrator account or the driver for the LAVA card is not installed.
George
Logged in as administrator.
In device manager, in LPT1, address lpt1, I get the message "Device working properly"
In device manager, in LPT1, in Drivers tab, it shows Lava PCI Parallel.
Autodetect not working.
Kerry
Get the I/O range from the Device Manager and enter it into the software Hexadecimal address. Set the Filter Resource in Port Settings in Device Manager to Always use an interrupt and Enable legacy plug and play.
George
In device manager, the i/o range states "BF00-BF07". I type that in instead of the "378" that is currently in base address (hexidecimal)?
Kerry
Well, that didn't work.
Kerry
Any help with this would be greatly appreciated!
Kerry
