587,466 active members*
3,150 visitors online*
Results 1 to 7 of 7
    Feb 2012
    19
    Counterbalance top up
    hi, i have a VFOE, and the nitrogen counterbalance needs topping up.
    i have bought some dry nitrogen and borrowed a haas regulator, but would like a step by step way of topping up the counterbalance tank.
    thanks!!
    Feb 2010
    1184
    Quote Originally Posted by deadjam View Post
    thanks!!
    The nitrogen tank mounted on the machine should list out required PSI for different machines, find the pressure listed for your machine.
    - Jog the Z-Axis all the way to the top (+)
    - The hose end that connects to the machine will have a schrader valve with a T hande, make sure it is all the way open counter clockwise.
    - Connect both ends of the hoses
    - I usually charge without a regulator but sssslllllooooooowwwwlllllyyyyyy crack open the nitrogen fill tank just enough until you hear it filling.
    - Charge to the recommended pressure (I usually go 50psi over as it usually drops when disconnecting and jogging up/down the first time.)
    - When recommended pressure is reached, close valve on nitrogen fill tank, crack open the hose connection to relieve any pressure left in hose, then completely remove hose.
    - I like to cycle Z-Axis up/down and recheck pressure
    Good luck!
    Feb 2012
    19
    Quote Originally Posted by haastec View Post
    Good luck!
    thanks!!
    when filling with nitrogen, do you have to turn the tank on the machine the other way round so the oil doesnt drip out??
    Feb 2010
    1184
    thanks!!
    No, the schrader valve for the tank on the machine will keep everything in kind of like a check valve. The nitrogen pressure from the fill bottle will open it up to allow it to charge. When you close the fill bottle valve and bleed off the pressure in the hose, you will get nothing but a little bit of nitrogen. It will bleed off in a few seconds, nothing to worry about.
    Feb 2012
    19
    ok, just to clarify!
    when recommended pressure is correct, you turn off the valve on the nitrogen tank, then you slowely disconnect the hose from the machine end first or the nitrogen tank end first???
    also if the regulator doesnt show up on monday, what order do i connect the hose to the machine and nitrogen fill tank??
    Feb 2010
    1184
    When connecting or disconnecting hose, it does not matter which end goes on first.
    Feb 2012
    19
    many thanks for your info.
    all filled up without a hitch!!!
  1. My pneumatic counterbalance
    By davo727 in forum Charter Oak Automation Support Forum
    Last Post: 07-01-2018, 06:33 AM
  2. Hydraulic Counterbalance recharge
    By Kool Parts in forum Haas Mills
    Last Post: 09-08-2017, 12:35 PM
  3. Sieg X2 Mini-mill - Counterbalance or not?
    By Vogavt in forum Benchtop Machines
    Last Post: 05-10-2010, 02:12 AM
  4. HL1 Counterbalance Spring Broke
    By Geof in forum Haas Lathes
    Last Post: 07-26-2007, 06:37 PM
  5. Gas Spring Counterbalance (Swede???)
    By bill south in forum Mechanical Calculations/Engineering Design
    Last Post: 07-06-2006, 10:26 PM
