587,515 active members*
2,917 visitors online*
Results 1 to 15 of 15
    Apr 2009
    220
    Coupling makes noise
    Hi, I mounted the coupling on the ballscrew and motor and as you can notice in the videos, there is some noise from coupling not (maybe) being properly mounted on both ends but it is quite difficult for me to mount it without stretching the spirals of coupling.
    Do you have any idea/trick for doing this?
    Also, does the coupling needs to be sliding easily to the ballscrew and motor shafts? I needed to hit with a elastic-head hammer in order to insert the motor shaft into the coupling and then screwed the bolts of coupling to each shaft respectively.
    ??????0002 - YouTube
    ??????0000 - YouTube
    Thanks.
    Dec 2003
    24220
    Appears to be excessive misalignment of motor and driven shaft?
    Al.
    Albert E.
    Apr 2009
    220
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Hi, you mean that motor is not aligned correctly with ballscrew?
    Actually this the type of coupling I use:
    http://t0.gstatic.com/images?q=tbn:A...yWwN8vhRUYm5XA
    Also, another important note is that when I try to insert the motor shaft and the ballscrew shaft into the coupler, I meet some difficulty and i need to hit it with elastic hammer or push it very very much....is this normal?
    Dec 2003
    24220
    Excessive force should not normally be needed, Is this an aluminum you are using?
    For motor to B.S. a Stainless version should be used.
    An aluminum type, especially with that apparent misalignment is not going to last long.
    Al.
    Albert E.
    Jan 2006
    2985
    Looks to me like the motor shaft is bent and the motor is poorly aligned to the screw.
    Apr 2009
    220
    Al.
    Yes this is an aluminum coupling.
    The fact is that even if I align it correctly (having the spirals being equally distanced each other), when I move the Y axis, it is slowly misaligned and make this noise.
    Apr 2009
    220
    Quote Originally Posted by keebler303 View Post
    Maybe this is because my video was taken with mobile. However, I cannot see some bending or misalignement.
    Thanks.
    Jan 2006
    2985
    The top half of the coupling, in your second video, seems to gyrate. If it was simply misaligned, it should spin true. That gyration makes it look the like the motor shaft is bent. It's hard to tell from your video.
    If you get it aligned and then tighten everything down, how does it slowly misalign? This doesn't make sense.
    Apr 2009
    220
    I think that I fixed this issue:
    Please see below.
    CNC 1m X 2m - Part 4 - YouTube
    Jan 2006
    2985
    Looks much better!
    Apr 2009
    220
    Ballscrew turns hardly when bolts are screwed down.
    I am dealing with another problem right now in Z axis. When I screw the bolts (please see yellow circle in the first picture), then the ballscrew can hardly turn, but when I unscrew them a little bit, then the ballscrew turns ok.
    These two bolts are screwed on the small aluminum piece(please see the 2nd picture in red circle). Notice that when I insert the system(in green circled) on the rails, the small aluminum piece(in red circle) is smoothly osculates(touch) the aluminum plate(in green circle)
    Attachment 208408
    Attachment 208410
    Do you know what might be wrong when I screw these 2 bolts?
    Thanks again.
    Dec 2005
    602
    Sounds like your screw bearing block holes are not concentric. When you tighten those two bolts, you are pulling that block out of alignment with the blocks that are holding the screw. You might want to try shimming that bearing block out from the plate.
    Mark
    Mar 2006
    2712
    Or (1) the surface of the block holding the ballnut to the Z-axis is not parallel with the bore locating the ballnut. (2) The distance from the mounting surface of the block holding the ballnut to the bore does not match to the ballscrew. This would cause the ballnut to interfere with the ballscrew. This would be more easily noticed with the ballnut closer to the motor end of the ballscrew.
    Dick Z
    DZASTR
    Apr 2009
    220
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    So, do you suggest that I could try shimming between the block holding the ballnut and the aluminum sheet?
    Thanks...
    Mar 2006
    2712
    I would suggest making sure the plate you attach the ball nut mounting block to is parallel to the ball screw. Then I would determine the actual dimension from that plate to the centerline of the ball screw. Next, I would determine that the ball nut bore is parallel with mounting surface of the mounting block and the exact dimension from that mounting surface to the bore. Then if the dimension needs adjusting by removing surface material it could be milled or if it needs shimming to bring it in position that could be done. If shimming, make sure the shim is parallel so you do not create another problem.
    Dick Z
    DZASTR
  1. Gear box makes noise in high between 3000 & 6000
    By HEAVYDADAMAN in forum Haas Mills
    Last Post: 08-05-2023, 02:15 PM
  2. Stepper Motor doesn't spin but makes noise
    By Finder in forum Stepper Motors / Drives
    Last Post: 07-21-2016, 03:23 AM
  3. New K2 2514 Router makes noise
    By grossmanator in forum K2CNC
    Last Post: 11-17-2010, 07:35 PM
  4. crashed the machine, now spindle makes weird noise!!!!
    By lm6769 in forum CNC Machining Centers
    Last Post: 09-01-2008, 06:23 PM
  5. TAIG "head" makes alot of noise
    By Smertrios in forum Taig Mills / Lathes
    Last Post: 02-25-2006, 11:25 PM
