Hello i'm tony from Italy
:wave: see the new radial engine project :wave:
----------------- (chair) sorry for my English (chair) -----------------
nearly ended!!!!!
*****SOLD*****
sweet. Is that a kit?
Eric
I wish it wouldn't crash.
Ciao Tony, Io sono Andrea, de California, tutti mea familia e de Palermo, unaltra cinqua cugini, tutti con la nome Andrea Salerno. Una bella machina de te. Bravo! E' scusi mea lingua, e bruta Io la so. Noi odiamo Bush pura.
Halfnutz
hi Eric
is not to be one kit. but a toys between a job and the other---I do not have a plan. but I can make it if you want
the start project is
with . 3 cox engine 049 chokeplated
ciao Andrea .
anche mio fratello si chiama Andrea e siamo di Milano . il tuo italiano si capisce
((((hello Andrea . also my brother calls Andrea and is of Milan.
and I do not know well English (sorry for this ))))
regards
tony
How long are you expecting those gears to survive unlubricated at x000 RPM?
Regards,
Mark
I do not know it. !!? . I must try the resistance (are gears reducing of the battery bottoming drill) but the horses are little . the tree centers them with have two bearings
Hi Tony,
A few years ago, I started to build a 9 cylinder 2 stroke radial that was based on Cox .049 cylinders, pistons and rods. I got as far as the crankcase and front housing, but never got much further.
It was going to use a common crankcase and crankshaft (like a 'big' 4 stroke radial) and a vane type supercharger to pressurise the crankcase. This idea was based on the Berger 2 stroke radial that was available at the time. I doubt I will ever finish that project, and now when I look back, I was probably a bit optomistic...Cox .049's were often a pain to start when there was only 1 cylinder
Warren
I think this concept has possibilities but may need some refinements. Years ago when I was a kid, I used to fly the Cox .049's and yes they can be tempermental at times. My concern is that since they are a reed valve engine, are those the reed plates behind the crankcases. The other concern is the size of the carb and air plenum. The carb seems a bit too big for the amount of displacement. I have a feeling the large size of the plenum will allow the air/ fuel mixture to slow down considerably allowing the mixture to seperate out and puddle in the bottom. An electric starter would be a definite help in starting this engine.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Yes, my Italian is not "complete", I know a little, but not fluent. I was there (in Rome and Palermo) last year, you are so lucky to live in such a beutifull country. Where do you live?
Halfnutz
hi Andrea
no problem
i'm live in Milano and I have two uncle also to Rome
---if you want you write Italian---
you ask if you want whichever thing from Italy
regards
tony
Very cool Tony, you will have to keep us upto date. I think thats a very neat idea to build a small radial engine. Have you fired it yet for any length of time?
Have a good one.
Dave
Hi
I have still not made ignition but I make all in little days
perhaps saturday or Sunday...........I hope!!!!
regards
tony
How about a bigger one???
I just happen to have those exact photo's.
hello boys
new job ......................
Cool stuff! Has it run?
Busy people!
