Originally Posted by
crane550
2. For your 2x material...DONT USE FRAMING LUMBER. I wish I would have gone to my local hardwood store and had them cut me something custom and paid $30 for the wood, instead of $9 for the 3 2x4's I have needed so far. Even if it looks straight in the pile, it is not. Nor is it square. I have been fighting this all day.
If those 2x4 pieces continue to give you trouble, make new replacements by gluing two layers of the 1x4 clear pine together with the annular rings opposing each other like (). Use 60 minute epoxy or a good coat of Titebond yellow glue. You'll end up with the same 1.5" x 3" physical size with nice square corners.
When I built my Solsylva 25x37 I ruled out the 2x4 lumber right away because they are not stable with time and decided it was going to be made of poplar or red oak. Both are expensive, but I ended up using red oak because the bolts don't sink in so easily when tightened and it just looks so much better than poplar. That was the best decision that I made on that build. It cost me around $80 for the wood though.
The 25x37 uses EMT electrical tubing. After 1.5 years of very light use it is starting to develop some flat places where the bearings roll but it will be a long time before they need to be replaced.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
