588,563 active members*
5,266 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Created a front tool poste lathe in Mastercam X5, but the X axis is wrong..
    Apr 2013
    10
    Hi guys,
    I fiddle with Mastercam X5 now for 1.5days, and I just don't get Mastercam to generate working NC for my now-CNCed lathe.
    The problem is that the values in X are output as negative values while in the drawing it is positive (+D).
    On screen the tool approaches the part from the bottom (+D direction), which is according to my lathe's setup.
    The machine in MCAM is defined as a typical lathe with a lower left turret with X and Z.
    I've attached some setup screens so you guys can maybe help me out here - would really appreciate it!!
    Regards,
    Dan
    Jun 2008
    372
    Re: Created a front tool poste lathe in Mastercam X5, but the X axis is wrong..
    the issue is in the post, the X has been reversed
    Apr 2013
    10
    Hi budgieW,
    you are refering to the picture of the X axis configuration, right? That's what I wanted to point out. Regardless of how I am changing the positive axis direction setting (tried both, positive and negative Y), it still considers the bottom half to be the negative X one. That's somehow very strange..
    Best regards
  1. Mastercam Lathe - Switch between D axis, and X axis
    By rjCousineau in forum Mastercam
    Last Post: 04-13-2015, 07:33 AM
  2. Lathe with Front and Rear tool posts
    By slammers in forum Mastercam
    Last Post: 05-31-2009, 10:49 PM
  3. Change Front Tool post Option
    By Moondog in forum Mach Lathe
    Last Post: 01-01-2009, 01:40 PM
  4. Help! Created 3-axis pocket code
    By tikka308 in forum BobCad-Cam
    Last Post: 11-04-2007, 07:26 PM
  5. need help fast 5 axis tool path in mastercam
    By fasttom in forum G-Code Programing
    Last Post: 12-02-2005, 07:22 AM
