587,157 active members*
3,809 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Creating angled joints on cast acrylic
Results 1 to 6 of 6
    Jun 2016
    9
    Hi everyone,
    I am having an issue finding the right tool to create a certain angled joint for a part I am making for a dispenser. I am using a 6mm cast acrylic sheet, and a CNC Routing machine (Model: SignKey-1325WDC). I have uploaded a sample that I drew up to be more clear. I am wondering what type of spindle I need to create an angle like this. Thank you for your help.
    -J
    May 2015
    1422
    Re: Creating angled joints on cast acrylic
    You can profile it with a bullnose cutter in passes, it will need some finishing. If it has to be perfectly flat, can you mount the sheet at the desired angle off the bed for this operation? If so, you can do it in one pass with a normal endmill.
    Feb 2016
    381
    As suggested flat end mill with work angled is likely best way to go, both you and your machines accuracy will be tested with sharp edge no matter how you mount this piece.
    Jun 2016
    9
    The surface is not adjustable on my router. However I will try out the bull nose cutter. Thank you for all of the suggestions.
    Jun 2004
    6618
    We make similar cuts in polycarbonate and use a table saw. You can clamp the parts in a dedicated sled and use good high tooth count blades.
    Lee
    May 2015
    1422
    Quote Originally Posted by doro_jason View Post
    No matter how close you make successive passes, a bullnose is still going to give you scalloped valleys down the length of the cut. If it needs to be flat flat, an endmill is the go but you need to present the material to the cutter at the right angle.
    I understand that you can't adjust the bed, not many routers would let you do that (although a 5 axis router would let you pivot the tooling to the correct angle on flat sheet). What you can do is make an angled spoil board or a frame which sits on the bed and to which you may clamp your material so that it presents at the correct angle. If you need it done flat as flat, this is probably the simplest way.
    HOLD THE PHONE: There's an easier way! Just use a drill bit. With an included angle of 118º, that's 59º from vertical or 90-59 = 31º from horizontal, which is in your range. And I'll bet you have a 1/4" bit or two kicking around the shop. Just make sure it's sharp.
  1. Replies: 28
    Last Post: 05-23-2016, 08:57 PM
  2. Anyone machined cast acrylic sheet?
    By kvom in forum Novakon
    Last Post: 03-29-2014, 01:21 AM
  3. How large air compressor to use for cast acrylic?
    By Metalmidget in forum Tormach Personal CNC Mill
    Last Post: 09-06-2010, 08:04 PM
  4. Optimal Carbide Insert for Cast Acrylic
    By bdphillips03 in forum Glass, Plastic and Stone
    Last Post: 01-27-2009, 04:57 PM
  5. Cutting 2" cast acrylic
    By routski in forum Material Machining Solutions
    Last Post: 01-11-2008, 09:44 AM
