603,967 active members*
2,044 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Creating elliptical surfaces/toolpaths
Results 1 to 6 of 6
    Sep 2012
    Hello all, Have browsed the forum and think its great. Relatively new to MC X5 and am having a tough time with something and I hope you can give me some pointers.
    I'm trying to create a raised ellipse, say 1.5 x 1 and about .2 high. Imagine a slice of an egg but not quite in perfect half. When I try to do a revolved surface I get some wild helixes and a central, round surface. If I so a rough and finish parallel toolpath on it, the tool follows these wild paths way off the surface of the ellipse and creates something more akin to a dough-boy helmet versus a domed ellipse. A swept surface is similar.
    I've about hit the wall on this and am looking for some tips. I can do regular circles just fine, but these ellipses seem to be different beast. In short, I need to make a .2 raised 1.5 x 1 ellipse and the corresponding toolpath.
    Anything is helpful; I've already gleaned lots of great stuff off this site.
    Best.
    Jul 2003
    1220
    Removed...Not MC Related
    Feb 2008
    51
    I used net on geo that you see on screen - when it came to pick chain I used single - did left side first and mirrored To the right. When I tried to net lower right and took off shading gave me weird surface? That's why I mirrored .
    Let me know if it's good. Thanks
    Tony DiSanto | Application Engineer - MasterCam Instructor Prism Engineering, Inc. | 455 Business Center Drive | Suite 225 | Horsham | PA | 19044
    Phone: 215-784-0800 | Fax: 215-784-0945
    Sep 2012
    Hmm...I am still getting the odd net lines with that. At times I can get it very close, but if I specify an ellipse as a base, then an ellipse as the top and an arc between the two I would think it could interpolate it ok. I often get one side ok (as you seem to see) and the other side the net lines go off the part...odd....
    May 2004
    4519
    I still have not figured out yet what you mean by "raised ellipse". Something like this?
    Attached Files Attached Files
    Sep 2012
    HI, as far as the raised ellipse, just hold an egg in your hand and imagine a plane slicing off a bit. You will have an elliptical contour but with a raised/domed surface. I'm sure there is a real name for this, I just don't know it.
    I ended up using net and drawing a very small ellipse at the top of my part and then liking the two ellipses with arcs and that got me where I needed to be, not perfect but pretty good.
    Thanks for the ideas and help!
  1. Creating surfaces
    By Clyde_06 in forum Surfcam
    Last Post: 09-19-2011, 07:47 PM
  2. putting toolpaths to surfaces
    By swannytheswan in forum Mastercam
    Last Post: 05-12-2011, 10:31 AM
  3. Strange toolpaths from mirrored surfaces.
    By Jim Estes in forum BobCad-Cam
    Last Post: 01-15-2007, 05:18 AM
  4. Creating Toolpaths for IGS
    By dneisler in forum Mastercam
    Last Post: 01-14-2007, 03:37 PM
  5. need help creating surfaces
    By CNC Darren in forum Rhino 3D
    Last Post: 10-21-2005, 11:08 PM
