603,365 active members*
4,116 visitors online*
    May 2007
    312
    Creating shaped tool
    Has any one had luck creating a shaped tool? So far going by the .pdf starting on page 177 I am going no where.
    Oct 2007
    499
    I use shaped tools all the time - use the help screens to get detailed help.
    When you come to define the shape chain, switch over to the SW feature tree and insert a sketch at the top level of the assembly, draw the tool shape (only half of it) and then use this sketch to define the chain.
  1. "Creating room for a large size tool" (SMTC)
    By l u k e in forum Haas Mills
    Last Post: 10-11-2010, 06:15 PM
  2. Creating Tool paths with a solid
    By Rathi in forum Mastercam
    Last Post: 07-22-2010, 04:04 PM
  3. Need help when creating surface tool path
    By gorby in forum Mastercam
    Last Post: 11-25-2009, 02:25 AM
  4. creating a custom tool
    By tomzap in forum Mastercam
    Last Post: 07-18-2008, 10:34 AM
  5. Creating tool paths
    By CNCMike in forum Mastercam
    Last Post: 04-15-2008, 09:38 PM
