588,033 active members*
5,423 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > Crosshatch/Mesh pattern on casting surface...Why?
    Jun 2003
    453
    I've seen on some cylinder head castings a mesh or crosshatch pattern, with lines about 5mm appart about 2mm high. It's too small to be structural or for heat dissipation. Can anyone tell me why the grid is there.
    Cheers
    Splint
    Apr 2003
    76
    Couple differanrt possiable reasons.
    One is in the mold we sometimes Have a HOT spot that just does not cool quick enough and there for creates a porosity area. To solve this we need to cool this area. we will sometimes add a CHILL to this area, It can be a steel block or a differant piece of material that will aid in solidification.
    Sometimes we add this cross hatch patern to the block we are adding and sometimes to the mold itsself and put water cooling in the mold.
    Hope this answers your question It is mainly for solidification of the part. Usually.
  1. Convert 3D mesh to 3D polylines
    By ger21 in forum Autodesk
    Last Post: 08-10-2007, 07:13 PM
  2. Importing polygon mesh (.dxf) into BobCad
    By rherman in forum BobCad-Cam
    Last Post: 06-10-2005, 08:08 PM
  3. Need help on G75.1 pattern repeat
    By wayne mitchell in forum G-Code Programing
    Last Post: 03-16-2005, 09:49 PM
  4. RHINO 3D Mesh
    By infinti_bc in forum Mastercam
    Last Post: 04-05-2004, 01:32 AM
  5. Pattern Systems
    By DanFri in forum Uncategorised CAM Discussion
    Last Post: 05-02-2003, 04:55 PM
