603,870 active members*
2,726 visitors online*
Results 1 to 4 of 4
    Apr 2017
    3
    CRT LCD REPLACEMENT ISSUE
    *Apologize if this is not the best thread for this question. Newby here*
    I have a Hitachi Seiki HT20S with a CRT monitor that went dead and Ive replaced it with a new LCD monitor. I wired to the manufacturer's spec and its works... up until I press standby. With the machine initially turned on I get my NOT READY screen and have the ability to go and view my command, program, parameters, offsets etc.. pages just fine but as soon as I go into standby the screen goes black. I've been trying to contact the manufacturer but they are in china and the time difference has me waiting til the next day. I need to get this machine running. Does anyone have a idea what might cause this or how to fix this issue?
    Thanks!
    Dec 2009
    559
    Re: CRT LCD REPLACEMENT ISSUE
    Whats the control? That will make a difference. Some need converters, but seeing as you had a CRT it all you really need is the R,G,B HSync and VSync to make it work. How do you have it wired for power?
    John
    Apr 2017
    3
    Quote Originally Posted by shas595 View Post
    John
    Controller is Seicos LB Mark 2. Weve soldered straight to the board. Currently using the 110AC/12v power supply they sent, and am just powering the monitor from a external source until I get this working.
    Dec 2009
    559
    OK - i80 should be coming off the FC960 behind the control - 1 Vsync, 2 HSync, 3R, 4G, 5B - thats all you need
    If you are using an external P/S then its not that - possibly leaking voltage and going in to reset once you hit standby - check to see if you have those pins correct (likely do since you can see something already) and make sure they arent crossed or touching anything else
  1. Incoming Power Issue, or Transistor Issue
    By barchdesigns in forum CNC Machine Related Electronics
    Last Post: 08-19-2016, 10:32 PM
  2. Chinese stepper motor stall issue, replacement questions
    By canman77 in forum Chinese Machines
    Last Post: 06-05-2016, 03:55 PM
  3. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  4. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
