587,218 active members*
2,683 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > curious toolpath problem
    Nov 2013
    8
    Hi everyone,
    I am milling architectural models for university students on a 4x8 AXYZ converted to Mach 3.
    Rhinocam creates the toolpath.
    In the picture, the stepover is 30 thou with a 1/4" ballnose.
    At the end of every pass, the toolpath changes. It looks to me like the Z is raising slightly to make the stepover appear wider (60 thou). It doesnt matter how slow I go (speed is 80 ipm)or which cutter I use.
    Does anyone have any ideas what could cause this ?
    There is no play in the spindle and the problem starts gradually, then becomes static at about 1.5" in length.
    Brant
    Aug 2019
    339
    Re: curious toolpath problem
    You need to post the program/gcode, and ideally the settings you set in your cam. That way I'm sure someone will be able to give you a hand.
    Without this minimum there is absolutely no way anyone can figure out what could be wrong, if anything.
    Let them know when you can! G'luck
    if you see raising Z in your program lines, problem on cam. otherwise probobly your part is not placed correctly.
