Just getting around to building my CNC. I have been playing with the X-axis and found some odd behavior.
One problem was starting the axis movement after sitting more than 10 seconds, even thought J4 was on (current reduction disabled).
Second problem was erratic stepper motion at very slow speeds, like .1 mm/s or lower. I think this is due to the "sync" modes changing.
I'm hoping to do this mod and fix the problem. If I don't want the computer to control it (pin 1) where could I connect the wire to on the board (or a manual switch)?
Otherwise the x-axis is working very good at normal and high speeds.
Thanks for the tip.
