587,319 active members*
3,376 visitors online*
Thread: Custom Probe
    Aug 2015
    58
    Custom Probe
    I've got a situation where I need to find the center axis of a vertical rod with a digital probe. So kind of the opposite of finding the center of a hole. I need to do it many times and am realizing I could save a lot of time if I wrote a sub routine to do it. I'm no gcode expert but I can probably write some code to do what I want...eventually Before I do that though I thought might check on the boards here and see if someone had already written something like that or if maybe there is another solution I'm not considering. Thanks
    Nov 2005
    218
    Re: Custom Probe
    Does the pathpilot circular boss probing routine not work for you?
    Aug 2015
    58
    Re: Custom Probe
    Quote Originally Posted by jcposada View Post
    Wow, I'm an idiot. If we could all pretend I'm not a big dummy after asking that question that would be great
    For some reason I thought the circular boss probing routine was for a horizontal cylinder, something that might be used before turning. Looking at it now its clearly not, don't know why I thought that. Thanks jcposada.
  1. can you use a probe and mach3 to auto probe a part?
    By skyguynca in forum Uncategorised WoodWorking Machines
    Last Post: 11-28-2013, 01:21 AM
  2. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  3. Super Probe 17 Functions in one probe
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:46 PM
  4. Custom bending a custom extrusion
    By brokenrinker in forum Bending, Forging, Extrusion...
    Last Post: 12-15-2007, 03:28 PM
