587,913 active members*
4,057 visitors online*
Thread: custom tool
    Feb 2009
    214
    custom tool
    I know I posted in here about a custom endmill, one with a 1/8" shaft and 1/16" cutter ball end, but can't find it.
    I have created one and i get an error message.
    i wanted to find the post that I read about and see if I missed a step.
    David L. Aery
    www.hooksolutions.com
    Oct 2006
    73
    Re: custom tool
    That line going up the middle of the tool looks suspicious. The error message you received usually occurs when the assigned tool geometry can't be modeled in the simulation. Remember, solid lines for cutting edges and dotted lines for non-cutting edges like shanks and cutter bodies.
    https://youtu.be/h4o52I9hZU8
    Hope this helps
    Feb 2009
    214
    Re: custom tool
    Quote Originally Posted by bishb25 View Post
    Hope this helps
    Thanks!
    I missed the dotted line thing, changed the drawing and now that part looks right.
    Finally got it. The video was very helpful.
    This also showed, (which I already knew,) that this tool would not work in the cavity I was cutting, the larger diameter shaft would rub on the side, but now the simulation verifies that.
    Thanks again!
    David L. Aery
  1. custom tool sheet
    By imachining-6061 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-10-2014, 10:05 AM
  2. Help! Custom tool
    By bassdo in forum Mastercam
    Last Post: 03-14-2014, 02:47 PM
  3. Custom tool drawing
    By petesurrey in forum Mastercam
    Last Post: 04-10-2013, 08:13 PM
  4. Custom tool makers?
    By LEWENZ in forum CNC Tooling
    Last Post: 04-26-2008, 03:45 AM
  5. xp custom tool paths
    By Mortek in forum OneCNC
    Last Post: 06-29-2003, 11:28 AM
