588,671 active members*
6,341 visitors online*
Results 1 to 8 of 8
    Apr 2016
    13
    cut alumiuim with cnc machine
    Hi There
    I have a cnc machine but very little experience.
    I want to cut 3mm alumiuim with a pattern on the surface (non slippy pattern )
    I tried 6mm end mill tool
    I set the speed to 6000
    The tool snapped after a few minutes
    Can someone please advise me what is best bit to use ?
    What speed shall I set the machine
    Do I need to oil bit during the cut ?
    Many thanks in advance
    Nissim
    Dec 2008
    3144
    Re: cut alumiuim with cnc machine
    Quote Originally Posted by Nissim6811 View Post
    Hi There
    Nissim
    More info
    - what are the cutter specs ?, how many flutes ?, is it an alum cutter (HSS, carbide, coated, not coated.....it needs to always be sharp ) ?
    - what feedrate ? what depth of cut ? width of cut ?
    - how are the chips removed ?
    - what is available to you to use in the way of air, coolant, etc to remove chips ?
    - guards to limit swarf & coolant spray ?
    - what machine are you using ?
    Generally, you need to get the chips away from the cutter, by using air, air/coolant, or straight coolant.
    - the coolant could be a proper soluble oil emulsion, WD40, kero, or a mix with water to stretch it out ( this also helps to limit the material sticking to the cutter )
    - the feedrate depends on a lot of factors, ie width/depth of cut, # of teeth, tool "stickout", work holding method...... just to name the main ones
    Your RPM is too slow ( cutting speed works out to be 113 m/min...which is for steels ), what is the max RPM of your machine ?
    - alum is roughly 4x the cut speed of steel,
    You may have gotten the tool too hot, & possibly it packed up with chips....causing the tool to not being able to cut any material....
    - I guess you got a fairly decent burr where the tool ended up breaking ?
    Apr 2014
    432
    Feeds there a good thing too.
    Dec 2009
    166
    Okay I know that if you use G-Wizard the feeds and speeds will be very high I have never been able to use the feeds and speeds calculated by G-Wizard even with Flood cooling the ally still melts and sticks to the tool.
    I just finished cutting some 3mm Marine grade alluminium useing a 6mm 4 flute Hss tool
    These are the feeds and speeds that worked really good I was also useing flood coolant just water with some soluble oil added
    Spindle RPM = 3000
    Feed rate = 160
    Plunge rate = 50
    full width cut i.e 6mm
    depth = full depth i.e 3mm
    Leave 1 mm for the clean up
    Finish pass I used calculation from G-Wizard
    Spindle RPM = 17465
    Feed rate = 1349.7
    Plunge rate = 251
    but I think i would slow down the feed a little to maybe 1200
    these feeds are all mm per min
    And just to add all those tools that get the ally melted to them just drop then in a jar off Hydrochloric acid overnight and they will be good as new in the morning.
    Apr 2016
    13
    Thank you very much for your help
    I attached photos
    Dec 2008
    3144
    I attached photos
    Feedrate looks a little toooo high ( 6x )
    you need to slow your feedrate down ,,,, say,,,,, 0.10 to 0.15mm / tooth,,,,, after you get it cutting, then, increase your speeds & feeds
    Some equations you need to learn
    RPM = ( Cutting speed / ( cutter Ø x Pi ) ) x 1000
    Feedrate / RPM / number of teeth = Feed per tooth
    so, you aye using
    9000 / 12000 / 1 = 0.75mm
    to go the other way
    RPM x feed per tooth x # of teeth = feedrate
    12000 x 0.10 x 1 = 1200 mm/min
    12000 x 0.15 x 1 = 1800 mm/min
    Apr 2016
    13
    Thank you so much !!
    I followed your advice and set up the feed speed
    Its perfect now
    Thanks again
    Nissim
    Jun 2010
    4262
    The reality is that the treadplate you are trying to mill is a horrible alloy and very unsuitable for CNC milling. It is just too soft and too sticky. I think, from memory, that it is a 5000-series alloy. Very cheap compared to the better 6000-series alloys.
    Yes, you can machine it with great care. Air blast and an oily mist to keep the cutter WET.
    If you get any Built Up Edge (BUE), you are seconds from disaster.
    Cheers
    Roger
