603,861 active members*
5,219 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > cut depth issues with stl files -vcarve pro 9
Results 1 to 7 of 7
    May 2018
    5
    hey guys, i am very new to cnc and the software for it, i am having cut depth issues in a pocket on an stl i am using.
    my materials are .5" and im trying to cut the pocket .375" deep but often it shows on the cut preview that it will ony cut .125. i dont know how to manually set cut depth on a stl. all the cut details are generated by vcarve pro 9.
    i have attached some files and a picture if anyone can help.
    any and all help is much appreciated!!!!!
    thanks
    Mar 2003
    35494
    Re: cut depth issues with stl files -vcarve pro 9
    3D toolpaths cut deth should be to the bottom.
    There are two exceptions.
    1) If the tool won't fit in the pocket, it won't be ablt to cut the entire depth.
    2) If the vector boundary does not leave enough room for the tool around the edges, then it won't be able to cut the entire depth.
    You should learn to do this job using 3D vectors instead of from an .stl.
    The toolpaths will be much more efficient, resulting in cut times of probably 10x faster.
    And the finish will be much better.
    Attach your .stl and V Carve file (zip them).
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2018
    5
    awesome thank you, unfortunately with the stl i dont even see an option for cut depth, (unless its called something different). I will definitely try to use that file! do you mean attach those files here in the thread? or in vcarve pro? thanks a lot for your help!
    May 2018
    5
    where do i need to attach my stl and vcarve file to? this forum or in vcarve?
    thanks
    Mar 2003
    35494
    zip them and attach them here, and I'll take a look.
    Gerry
    Mar 2003
    35494
    There isn't a depth setting when doing roughing or finishing passes on an .stl (or any 3D model). The tool cuts down to the model.
    Gerry
    May 2018
    5
    ok got you! here you go!
    Attached Files Attached Files
  1. VCarve Pro V9 upgrade No longer able to import 3ds files.
    By dvaskie127 in forum PhotoVCarve and VCarve Pro
    Last Post: 07-28-2017, 03:40 AM
  2. Depth of Cut Issues
    By Dave's_Not_Here in forum Techno CNC
    Last Post: 08-29-2014, 08:40 AM
  3. CAD files can be edited in VCarve Pro but not in Cut2D. Valuable feature?
    By CarySwoveland in forum PhotoVCarve and VCarve Pro
    Last Post: 05-20-2014, 06:34 PM
  4. Where are the .pp files for VCarve Pro?
    By vger in forum Post Processors
    Last Post: 11-01-2013, 06:17 AM
  5. Cutting depth issues
    By NylonAdmiral in forum Mastercam
    Last Post: 10-14-2009, 04:07 AM
