588,533 active members*
8,950 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Cut start position in 2d cutting?
Results 1 to 4 of 4
    Aug 2005
    828
    Can the lead in location be changed when doing a 2d profile cut? I cut different shapes and would like to have a the bit start in the same location. Now it just starts were ever it feels like.
    Dennis
    Feb 2007
    1084
    If visual mill is the same as RhinoCam, the start and stop of a closed curve such as a box is where the curve was last joined. For instance, I will draw something, then decide where I want the tool to radius in, cut and exit, then I put two points right next to eachother, split the curve using those two control points and re-join.
    Sep 2004
    264
    In Visual Mill the cut always starts at the curve start and travels to the end. Even closed curves have a start and end. In the edit curve toolbar, you will find a button which will allow you to change the location of the curve start/end and another for the direction. --ch
    Aug 2005
    828
    Thank you both, now I keep things standardized.
    Dennis
  1. multi start thread cutting on 10TF fanuc
    By calc in forum G-Code Programing
    Last Post: 06-17-2022, 02:14 PM
  2. Tool Start position
    By Mike.C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2008, 03:20 PM
  3. how to tell where the cutting bit will start?
    By BrassBuilder in forum Dolphin CAD/CAM
    Last Post: 03-24-2008, 06:55 PM
  4. Single start vs double start ballscrew.
    By darik in forum Linear and Rotary Motion
    Last Post: 03-22-2007, 01:53 AM
  5. Newbie about to start out with CNC hotwire cutting
    By boggyplanet in forum CNC Wire Foam Cutter Machines
    Last Post: 02-28-2007, 06:36 AM
