603,940 active members*
2,463 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut2D / Cut3D > Cut2D Drawing Slots Inside a Circle
    Feb 2015
    Hey guys, need your help.I am using Cut2D and I can't figure out how to insert three oval shapes inside of a five inch circle at 0, 120, and 240 degrees. I was able to insert three ovals (oval slot size is .25 x .75 with a .125 corner radius) inside of the circle, but not as those coordinates. I need the oval slots to face the center of the circle too.Does anyone know how to do that in Cut2D?Thanks for the help,Mike
    Aug 2005
    437
    Re: Cut2D Drawing Slots Inside a Circle
    In my opinion, Cut2D is ok for generating your gcode, but it comes up short as a drawing program.
    I would recommend using a free CAD program for drawing and import your CAD file into Cut2D.
    Try Draftsight (Free) your life will be sooooooo much easier.
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
  1. Radial Slots around a circle
    By lamina in forum G-Code Programing
    Last Post: 06-23-2011, 10:27 PM
  2. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
  3. TCC crash during pocket milling, polyline inside circle
    By StephanWenger in forum Uncategorised CAM Discussion
    Last Post: 12-02-2010, 03:36 PM
  4. Want to buy machined aluminum parts. PDF drawing inside
    By ChrioN in forum Want To Buy...Need help!
    Last Post: 09-20-2010, 08:36 PM
  5. inside circle cutting problem
    By glenthemann in forum G-Code Programing
    Last Post: 12-08-2009, 11:00 PM
