the program I am trying to run alarms out in graphics. It says the cutter Diameter to big for cutter comp to be applied. I am cutting around the outside of a part using Gibbscam. I have changed the lead in lead out to rediculously big numbers and it still can not do it. Could this be a postprocessor issue? If so is any one here using gibbscam with a haas minimill, that would have a post they can share?
