603,940 active members*
2,162 visitors online*
Results 1 to 4 of 4
    Jun 2006
    95
    Cutter for curved surface?
    I am looking for the best method/tool for cutting convex or concave type surfaces? Does anyone have a good way to do this so that the finish is not to much work to sand down?
    Feb 2009
    2143
    A ballend mill cutting with a small stepover (like .001 - .005 inches).
    Aug 2008
    409
    Ball nose is your best bet, depending on the detail needed, I use a 1/8 and 1/4" ball nose for most of my 3d work.
    You can get pretty good finish if you use a small stepover but the trade off is increased machine time.
    Oct 2006
    669
    Depending on the size of the work piece, cutting the surface with a fly cutter mounted in the spindle as the work piece rotates, will give you much better results than a ball mill ever will....and you can cut both convex and concave shapes with the same tool and slightly modified programming....inverting x or y, depending on which axis the 4th is mounted on
  1. Engrave on a curved surface
    By keebler303 in forum ArtCam Pro
    Last Post: 09-04-2009, 01:03 AM
  2. Help with projecting a setch on to a curved surface
    By Craigpat in forum Solidworks
    Last Post: 02-10-2009, 02:59 AM
  3. Curved Surface Toolpath
    By ehsanmax in forum Mastercam
    Last Post: 03-14-2008, 12:39 AM
  4. Engraving a curved surface?
    By wyobmf in forum Rhino 3D
    Last Post: 05-29-2007, 03:13 PM
  5. text/dingbat to curved surface?
    By Dougotio in forum Rhino 3D
    Last Post: 01-19-2006, 01:58 AM
