587,143 active members*
5,602 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cutting Aluminum Sheets.
Results 1 to 4 of 4
    Hello,
    I work for a sign business and we got a cnc router a few years ago.
    We have since mastered cutting most sign materials except aluminum sheets.
    Currently I want to cut around 200 5"x2.5" plates out of .060 aluminum.
    I believe the alloy is 3105 if that matters.
    Our table is 4'x2'.
    The problems we normally face are rough edges and lifting as well as aluminum gumming up on the bit.
    We use to adhere the material to the table with spray adhesive, but have since moved on to double sided tape.
    The most success I've had is VERY shallow passes, but it takes so long its not worth the time.
    We feel like the sheet is so thin there has to be a way to cut through in 1 or a few passes.
    If someone who cuts similar material could recommend a specific bit with speeds and feeds it would be greatly appreciated.
    Thanks!
    Mar 2017
    411
    Re: Cutting Aluminum Sheets.
    You might think about using a different alloy. 3105 has poor machinability qualities. Also, when machining aluminum plate on a router, you need to be careful about your speeds and feeds and ramp into your cut. A very thin chip with high RPM will tend to gum up the cutter and cause a failure. Finally, use a cutting fluid. It will help the chips from gumming up on the bit. I often just use WD-40.
    Often people have a tendency to take a smaller cut and increase the RPM when that is the opposite of what is needed. As far as the end mill, I have always had good luck with YG1 Alu-Power.
    Apr 2004
    5740
    You might think about building a vacuum table, powered by a pump, not a shop-vac. It sounds like a lot of your problem stems from not holding the sheets down firmly enough. Also, using a heat-treated grade of aluminum sheet intended for machining will help with gumming up your cutters.
    Andrew Werby
    Website
    Feb 2006
    992
    Seem like work piece is hold down good enough and the speed is too slow plus no cooling to flush out the chip, it getting right back into the cutting edge.
    Can't see what the job is like to can't give any idea how to hold the pieces, .06 thick Aluminum with a decent with cnc should has no problem cutting it.
    - - - Updated - - -
    The best way to learn is trial error.
  1. Plasma cutting machine for cutting Thick sheets
    By aaronhernandez in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-14-2016, 01:38 PM
  2. Where can I by 50% Nickel 50% Aluminum Sheets
    By Moffett8 in forum Want To Buy...Need help!
    Last Post: 05-08-2009, 04:52 AM
  3. Cutting 1" sheets of aluminum.
    By Kalvin in forum Benchtop Machines
    Last Post: 05-07-2009, 05:32 AM
  4. Looking for feed rates on aluminum sheets
    By eric_bilodeau in forum MetalWork Discussion
    Last Post: 02-04-2006, 03:51 AM
  5. Cutting Aluminum Sheets
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 05:12 PM
