587,178 active members*
4,048 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > CUTTING BEVELED ANGLES
Results 1 to 4 of 4
    Apr 2005
    This type of question may have been asked before, but I found not find it in the forum.
    In the future I am planning on building some horn-loaded speakers like the Klipsch Lascalla, Belle or Khorn. There are numerous non-standard (i.e. 11, 19, 29 61 degree) beveled edges. Is it possible to cut good fitting beveled edges on a 3 axis router without resorting to the purchase of custom ground router bits?
    Mar 2003
    35538
    Yes, it's possible. But it's probably not the most efficient way to do it. And you'll need to figure out how to program it. But it is possible.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2005
    So, it would seem to be better to cut out the panels oversize on the router and then cut the bevel on a table saw?
    Mar 2003
    35538
    It would be faster to cut the bevels on the table saw, imo. So if faster = better, than yes.
    Gerry
  1. 90° Beveled Gearbox ?
    By twocik in forum MetalWork Discussion
    Last Post: 06-21-2008, 08:20 AM
  2. Need Help horizontal part lots of angles
    By chuy in forum Mastercam
    Last Post: 01-11-2008, 11:29 PM
  3. slopes and angles
    By massbaster in forum Sharp CNC
    Last Post: 07-12-2007, 04:14 AM
  4. how to mill angles?
    By cowanrg in forum MetalWork Discussion
    Last Post: 05-14-2007, 03:35 PM
  5. Beveled 1/8" endmills?
    By saturnnights in forum MetalWork Discussion
    Last Post: 03-27-2006, 01:48 PM
