588,487 active members*
5,506 visitors online*
Results 1 to 4 of 4
    Dec 2011
    75
    Cutting Delrin (Acetal) with Laser Cutter...
    I need to cut Black Delrin with the thickness of 4,5,20 and 25 mm. I didn't cut Delrin before with a laser cutter; instead I used my old CNC Router, but it's a pain in the 12. Since I have a 150W Reci Tube, I wanted to try to cut it with the laser. What do you know about cutting Delrin with Laser?
    Dec 2011
    75
    I just cut 4mm black Delrin and it smells horrible. It's vapor burns my eyes,nose and throat. Really nasty thing.
    May 2010
    26
    I think burning acetyl produces HCL and phosgene, nasty stuff.
    Jan 2006
    2985
    From MSDS
    "Conditions to avoid: Heating above 230°c / 446°f forms formaldehyde."
    You are surely exceeding that when you zap it with a laser beam.
    http://www.cityplastics.com.au/pdf/acetal%20msds.pdf
    Matt
  1. Cutting HDPE and Acetal sheets with a CO2 laser ?
    By nio101 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2012, 06:43 AM
  2. Machining Acetal/Delrin guides
    By PMOrthotics in forum Glass, Plastic and Stone
    Last Post: 03-06-2011, 03:09 AM
  3. Delrin/Acetal Guides for an X2
    By n1bpd in forum Benchtop Machines
    Last Post: 09-01-2009, 02:03 AM
  4. Is this Delrin/Acetal?
    By HackMax in forum Benchtop Machines
    Last Post: 06-21-2009, 01:29 AM
  5. deburring acetal/delrin
    By acidcustom in forum Mass finishing equipment/media/strategies
    Last Post: 03-26-2007, 01:26 AM
