588,073 active members*
4,873 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Cutting depth and length of flute.
Results 1 to 8 of 8
    Jul 2010
    567
    This is a rather dumb question but I'm not experienced and I'd like to know.
    If I say had a 1/4" endmill with .450" of flute length and I want to cut out this profile at .8" deep can I do it with a (relatively speaking) short flute length?
    http://upload.wikimedia.org/wikipedi...sat_mosaic.jpg
    Mar 2003
    35538
    Most likely, if the shank is rubbing when you get deeper than the flutes, you'll get burning from the friction of the shank. You'd be better off with a tool with 1" flutes.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2010
    567
    Alright I'll purchase some longer fluted tooling and keep on trying.
    Thanks for your help ger21
    Apr 2007
    8082
    Lowe's has Bosch router bits in 1/4" with 1" flute depth. They also have solid carbide up-spiral and down-spiral cutters. These will get you going until you find something more suitable to your needs. Home Depot probably has these in other brands.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Jul 2010
    567
    Ah the curse of living out here is Homedepot and Lowes are about an hour and a half away, going to Kona or Hilo is an ordeal...
    I'll order a couple longer fluted USA made carbide bits off of ebay.
    How do I out of curiosity roughly estimate life carbide bit life? I want to use smaller ballnose endmills for my projects, such a 1/32" for finishing(after a 1/8" fishtail rougher) of a 5"X6" topographical map but I'd have a rough idea of when I should toss my bit other then seeing poor finish quality. I like the finish quality I'm seeing but at the same time I don't want to be unnecessarily thrashing bits when an extra tool-change would be wise. The amount of material removal for the rougher verses it's bit diameter is also a question. I've played with leaving .1" down to .04" for a 1/8" tougher but I'm not sure what the rule of thumb is. I'm guessing it depends on my feedrate and RPMs...
    Apr 2007
    8082
    Mine usually break before they wear out, unless they are 1/4" or larger. I'm sure that someone has a formula for calculating wear, but it varies with material and a host of other factors. Not sure a formula will give you anything of use in the real world. Gerry may have a better idea what the industry uses. Probably just keeping records of the part numbers you buy is as good as it gets.
    CarveOne
    CarveOne
    Apr 2009
    5516
    Some websites list it. I don't know if Mach3 has cutter comp but many commercial machines have cutter compensation based on formula, others actually laser-measure the tool. Some CAM software does this.
    Carbide actually lasts pretty long in wood provided you don't heat it up too much when cutting. I would do as much roughing with straight end mills; ball endmills are way less efficient at bulk material removal, since the edge cross-section is about 28% less area, and the tip is virtually zero width; thus the stepovers have to be much smaller.
    What CAM software are you using? Sight unseen, I would re-rough with a 1/16" endmill (and then maybe even a 1/16" ball endmill) before trying the 1/32" ball endmill, since you may leave steps too large for the 1/32" endmill to handle.
    Also, these tiny endmills are a lot tougher than you think - I cut fret slots on my CNC with an .024" endmill, taking three .020" passes at 60IPM in ebony!
    Also look into tapered ball endmills; they're a lot stronger and should last a bit (no pun intended) longer than a straight ball endmill.
    Jul 2010
    567
    I am using Meshcam, it's a bit limited because I can't use any more then 3 tools at once without going against the grain and doing a hack.
    I have a single tapered endmill, I'll invest in a few more of them shortly when I finish a single project that looks really nice...
    Recently I gave a fishtail endmill a shot for roughing and I am suprised on how effectively they chew trhough wood
  1. Cutting deeper than flute length
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 12-22-2011, 04:49 AM
  2. Capturing flute length (max depth of cut) in SprutCAM
    By gsnorcal in forum Tormach Personal CNC Mill
    Last Post: 12-06-2011, 03:34 PM
  3. Cutting deeper than cutting length
    By magudaman in forum CNC Tooling
    Last Post: 10-10-2011, 04:36 AM
  4. Depth setter / tool length input?
    By thackman in forum Syil Products
    Last Post: 06-26-2008, 10:08 PM
  5. Possible to have more than 1 Cutting depth?
    By CJL5585 in forum SheetCam
    Last Post: 06-02-2005, 10:44 PM
