588,386 active members*
5,341 visitors online*
Results 1 to 5 of 5
    Jan 2007
    114
    Cutting fiberglass
    I am trying to cut a piece of fiberglass that is 1/8 thick, I have a universal laser cutter that has a 40 watt tube in it. I am getting a melting affect and a poor edge with 80 percent power and 2 in a minute with 150 PPI . Anny suggestions would be welcome.
    Dec 2006
    48
    increase cutting speed and lower power setting
    We useed to cut plastic by 40W CO2 glass laser and had same issue, then we switch to 60W and decrease the power setting a little bit and increase the cutting speed little bit, its working, edge looks neat. wish it helps
    Frank
    www.rabbitlaser.com
    Aug 2003
    494
    Just doing a follow up to see what success you had in cutting the fiberglass.
    Did it all turn out the way you hoped?
    Rich.
    I am not completely useless.......I can always serve as a BAD example.
    Jan 2007
    114
    Cutting fiberglass
    I have cut Acrylic, ABS , Rubbers , and a few other plastics, But I have not figured out how to cut fiberglass with much success. I have tried to lower power and do multiple passes to limit the burnt edge, but it still isn't pretty like acrylic.
    Let me know if you figure out a good way to cut it.
    Oct 2007
    18
    Do you have machines that can mill it?
    Most PCB shops use a hog-out type end mill to cut PCB material (fiberglass) and the edges look very nice (sorry if the description is not very clear, let me know if sources are needed).
  1. Has anyone tried fiberglass?
    By Tom Brown in forum Open Source CNC Machine Designs
    Last Post: 03-10-2009, 12:24 AM
  2. Lasers for Cutting Fiberglass/Phenolic
    By psiwaterjet in forum Waterjet General Topics
    Last Post: 11-26-2007, 05:22 PM
  3. Fiberglass Canopy
    By ShortRunCNC in forum Hobby Discussion
    Last Post: 05-22-2007, 09:02 PM
  4. Cutting fiberglass, what coolant?
    By SteveD in forum Community Club House
    Last Post: 10-23-2006, 02:42 PM
  5. polyurthene vs fiberglass
    By pyroracing85 in forum Material Machining Solutions
    Last Post: 02-11-2005, 06:53 PM
