Hi. I was wondering how one would go about cutting internal threads for acrylic tubes with internal diameter's varying from 1.75 - 2.25"?
An example:
http://www.performance-pcs.com/catal...s/15700_01.jpg
I was thing a lathe. I saw a guy cutting external threads for a steel rod using a lathe by constantly starting and stopping the machine going back and forsth with the drive system. I thought that maybe I could do that. That would be very hard though because I only want to thread in about a 5/8". Would be hard determining when to stop the lathe. Plus,... I would have to turn the lathe slow to make it easier to stop at a certain point inside the tube. Acrylic doesnt really cut all that well at really slow speeds.
I was thinking about converting a manual lathe into cnc lathe but im sure that would be very painful seeing that the bit would have to know exactly the chuck is on it's rotation plane to make several passes to cut the treads.
Then I though that make there was a huge special tap out there somewhere? But im sure that would be a pain too.
What about using a mill or a router to cut the threads with the tubes mounted vertically with some special horizontal vgrooving bit?!?!? I dont know.
Any help/ suggestions would be great. Thanks.
