587,874 active members*
3,983 visitors online*
    Feb 2008
    Exclamation Cutting letters with outlines
    I have been working on a file in AI CS2, and have created letters in yellow (for help in expalaination), then copied pasted in back where I outlined them and changed the color to blue. As a set, the image views as a yellow word with a blue outline.
    Here's the rub: when cutting, bothe letters cut the same size, so I've lost the "outline effect"
    All is sent to "signcut", so create outlines is activated.
    When viewing in Signcut, the letters appear very close in size, but are definitely therw as two separate colors, as can be seen by viewing the selected colors only box.
    Any help would be greatly appreciated.
    Your problem is that the software does not see the outline.
    What you need to do is adjust the letters how you want them, then go to >Object>Expand.
    As a good practice, learn to work in fill only!!!!
    Once expanded, select your text and go to >Object>Path>Offset Path
    You will have to play with the setting to learn what size you want, but that will give you the correct outline to your letters, shape, etc.
    ~Kevin
  1. Cutting 2" Foam letters
    By routski in forum Material Machining Solutions
    Last Post: 01-10-2008, 11:57 PM
  2. Heidenhain ManualPlus 4110 - GTI and GTZ files - cycles and outlines
    By grzeniua in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-10-2007, 10:48 AM
