https://www.youtube.com/watch?v=WjUnx9nlCmI
Pls call us at 847-984-0882 for any question
Product link:
https://www.automationtechnologiesin...tter-machine-2
1000W: Carbon Steel: Max 12mm, S. Steel: Max 5mm, Aluminum: Max 5mm, Brass: Max 3mm
1500W: Carbon Steel: Max 14mm, S. Steel: Max 6.5mm, Aluminum: Max 6mm, Brass: Max 4mm
2000W: Carbon Steel: Max 16mm, S. Steel: Max 8-9mm, Aluminum: Max 8mm, Brass: Max 6mm
Machine with 3000 W laser Power will have high price
Specification:
Working Area: (1300 mm x 1300 mm) 51" x 51 "
Z-axis Travel: 4.7" (120 mm)
Continuous Wave fiber laser, 1.07 um wavelength
Laser Wattage: 1000 W/ 1500 W/ 2000 W/ 3000 W
Beam Quality: <0.373 mrad
Positioning Accuracy: <= 0.05 mm/m
Max. no load speed: 3200 inch/min (81m/min)
Machine Power Supply:Three Phase 208V, 240V or 480V
Power consumption: 10-30 kW (various by laser wattage)
Dedicated USA technical support from qualified technicians and engineers
Gross weight: 5,500 lbs
Air-Assist: Oxygen or Nitrogen
Driving System: Servo Motors XYZ Servo Motors:Schneider or Delta, Y 2x850W, X 1x750W, Z 1x400W
Unparalleled versatility for cutting various metals, including low carbon steels, stainless steels, galvanized sheets, as well as some high reflective metals, such as aluminum
Long Durability (Cast Aluminum Beam, High Temperature Annealing Solid Machine Bed)
Fully Protected Enclosure
Laser fully contained in fiber, no need for regular beam alignment
