603,939 active members*
3,160 visitors online*
Results 1 to 8 of 8
    Sep 2004
    179
    cutting text with a router
    hey guys, As my machine get closer to the almost but never done phase I have a question about cutting text into a a piece of wood. Kinda like a sign with the letters cut into the wood, what software are you guys using? After tweaking my machine I would like to try this.
    Darren
    May 2004
    350
    i use deskengrave and best of all it is free from http://deskam.com/deskengrave.html :cheers:
    Sep 2004
    179
    thanks!! I tried it but Mach2 didnt seem to like it but i will play with it
    Sep 2004
    16
    i JUST GOT MY ROUTER WORKNG TODAY AND TRIED THE DESKENGRAVE ON MY MACH2 AND IT SEEMS TO WORK. BOY I AM HAVING A NEW EXPERIENCE WITH THIS PROGRAM. I OWN A TORCHMATE CNC PLASMA CUTTER AND IT WAS EASY COMPARED TO MACH2.
    Sep 2004
    179
    I know what you mean but I have been using the demo version of mach2 for about 2 weeks and have gotten use to it, i still dont know it all but i'm getting there.
    Sep 2003
    1113
    Just a quick question [or 2 ~3, if I may]
    - How are you cutting the text? (In MACH2):
    1. Importing an image? I've done some neat house numbers that way, or
    2. Using the "Write Wizzard"? I haven't found much use for it yet.
    DeskEngrave seems to be easy to work with - I found I had to "fiddle" a bit to get the size lettering then moved back to MACH2 (for the house numbers in 1 above). Jim
    Sep 2004
    179
    I was making a DXF in DeskEngrave, importing it into sheetcam (wich i really like) so I can set the cutter right/left compensation and make the gcode. Then load the gcode in Mach2, so far this has worked the best.
    Sep 2004
    16
    One thing that I am having to figure out is how to import a DXF File into the lower left corner of the X & Y axis. If it is done in Autocad it seems to be relative to where it is placed in Autocad. If the file is done in Corel Draw, this does not seem to hold true.
  1. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  2. DXF export from Corel - Text cutting
    By maxxgraphix in forum G-Code Programing
    Last Post: 03-24-2005, 04:12 AM
  3. large 4x8 router for cutting foam boat plugs
    By waterboy in forum DIY CNC Router Table Machines
    Last Post: 02-09-2005, 04:59 PM
  4. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 04:08 PM
  5. CNC Router cutting Aluminum
    By 2Gs in forum DIY CNC Router Table Machines
    Last Post: 08-09-2004, 02:21 PM
