Hey Guys,
I've been milling a number of flat plastics (polycarbonate) recently and running into fixturing challenges as well as some feeds and speeds issues relating to swarf and was hoping I could get some feed back.
So the setup I am using consists of a sacrificial sheet on the bottom, layered with my main sheet on top. I use a strip of aluminium on the edges to clamp the sheet down.
Flat Plate Milling | Flickr - Photo Sharing!
This works pretty well with the 6mm sheets, but when I'm doing the 3mm sheets, I definitely see it flexing in the middle. The bowing is really noticeable during peck drilling as the cutting tool lifts up the plastic as the tool lifts.
Since I'm cutting a whole part out of the center, I also get a nub at the end when the part disconnects. It's easy to finish off but I'm wondering if anyone has any suggestions on how to do this kind of work easier.
As for the cut, I was getting a bit of swarf built up on the tool (enough to marr the surface of the plastic). I keep hearing that you can cut though this stuff fast, but I've been running at 200mm/min feed rate doing a 1.6mm DOC using a 1/8" endmill. 2200-3000rpm.
I'm thinking about trying something like this:
Solid Carbide Spiral Plastic 'O' Flute -ToolsToday.com- Industrial Quality Solid Carbide Bits
Wanted to get some opinions.
