588,127 active members*
5,381 visitors online*
    Oct 2003
    19
    Cutting tool shape for PCB milling
    What is the ideal tool shape for milling PCBs. The copper is about 20 microns thick but you cant expect the PCB to be mounted 100% flat. So I guess a cut depth of about 1/50inch would be OK. The milled path can vary be 0.01 to 0.03inch thick. Due to the thin copper layer, using a flat end mill causes a lot of edge unevenness.
    Apr 2003
    470
    Check out http://www.thinktink.com
    Think and Tinker sell bits specifically designed for PCB milling.
    Nathan
    Mechanical ething bit design
    Neomiller,
    There is no "best" design for an all purpose pcb etching bit. The tool shape depends on the application, the resolution that you are trying to achieve, and how much you want to spend on a bit.
    The cheapest hi-resolution bits around are "V" groove engraving cutters. They offer a good combination of tiny tip geometry (typ. 0.125mm), high strength, and reasonable life (50 to 100 meters in 37micron copperclad). Their disadvantage is that they require that either the board be held VERY flat or that you use an engraving machine equipped with some kind of surface following appliance (see LPKF, T-TECH, EverPrecision, MITS, Think & Tinker).
    Traditional end-mills that have been tuned for milling copperclad remove the necessity of surface following but at MUCH higher cost (go to: http://www.precisecut.com and look at the PreciseBit non-ferrous end-mills), shorter life, and lower milling speeds.
    As far as degree of penetration, you generally want to impact the substrate as little as possible. Just cut deep enough to remove the copper and the underlying adhesive layer (50 microns in 1 ounce copperclad and 33 microns in 1/2 ounce copperclad)
    Ron Reed
    Think & Tinker / PreciseBits
  1. What is high speed machining
    By Klox in forum Hard / High Speed Machining
    Last Post: 04-11-2014, 05:13 AM
  2. Tool length sensing!
    By Swede in forum FlashCut CNC
    Last Post: 05-07-2013, 04:38 AM
  3. Quick change tool system (milling)
    By mark c in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2005, 01:50 PM
  4. Tool Changer Problems
    By Snel in forum Haas Mills
    Last Post: 08-11-2004, 02:56 PM
  5. Best tool for cutting metal?
    By PsyKotyk in forum MetalWork Discussion
    Last Post: 04-01-2004, 09:10 AM
