587,990 active members*
5,658 visitors online*
Thread: Cycle times
    Feb 2010
    Cycle times
    I did a real world test. I have a program in Preditor Editor and backplotted it and got a cycle time of 04:41:05 which I'm assuming is 4 min 41.05 sec. Then I loaded the program into a machine and got a cycle time of 3 min 22 sec. Why arn't these much closer to eachother?
    Dec 2008
    4548
    I think the reverse post processor being used for Predator has to be edited to fit the settings that are being used (I could be wrong), though I also dont know enough about it to tell you what-where to change anything.
    There is a script made By a user in the BobCad forum that will produce more accurate cycle times without trying to figure out how to do the Predtor RP.
    Apr 2008
    1577
    Is this a lathe program or mill?
    I don't think Predator tries to get as accurate as .05 seconds, that looks more like 4H 41M 5S. I think I recall someone mentioning that some Lathe programs will backplot a feed of F0.006 (0.006 inches per revolution) as 0.006 inches per MINUTE!
    Burr's right, there are settings to be tweaked if you want to crack open the .MCH and .RP* files. It's very easy, just like editing your post processor. Good idea to back it up in case you make a mistake of course.
  1. Whacky Cycle Times
    By Technical Ted in forum Mastercam
    Last Post: 03-09-2009, 02:35 AM
  2. Prgram cycle times
    By Atlas_Too in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-15-2008, 07:31 PM
  3. increasing cycle times
    By thetrillionaire in forum Haas Mills
    Last Post: 04-09-2008, 05:03 PM
  4. Need help with Titanium cycle times!!!
    By HAMMER66 in forum MetalWork Discussion
    Last Post: 02-18-2008, 03:53 PM
