588,636 active members*
5,913 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > D2 drawn down toooo long
Results 1 to 4 of 4
    Jan 2006
    45
    I put some 5/16 D2 plates in the draw down oven after heat treating and than forgot about them. Total time at 400 degrees was about 4 hours. Are the plates ruined?
    Aug 2005
    129
    d2
    How much lower is the hardness, than what you were trying to get?
    Andrew
    Andrew Abken
    www.drewtronics.net - PCB Cutters
    Jan 2006
    45
    Well we just checked them and they are at 60 rockwell. I think we were shooting for 62 so they are not as bad as I thought they would be. This is the 2ed time that I've done this.
    Aug 2005
    129
    d2
    Yea, I remember the time I forgot to remove a 420ss plate from the oven at 1870deg - it was in for 10hrs not 1 hr like it should have been.
    I did not need to ask if the plate was any good, it nearly disinigrated!
    I doubt your plate suffered much from its long draw, if 60rc is acceptable I would think it to be just fine.
    Andrew
    Andrew Abken
  1. Replies: 11
    Last Post: 12-02-2007, 08:13 PM
  2. How Long/RPM
    By skydivebase in forum Haas Mills
    Last Post: 08-20-2007, 01:29 AM
  3. Click On Drawn Entities
    By TURNER in forum Visual Basic
    Last Post: 05-17-2007, 04:41 PM
  4. What have you drawn and built entirely on bobcad??
    By AMCjeepCJ in forum BobCad-Cam
    Last Post: 01-31-2006, 09:09 PM
