587,628 active members*
3,245 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo PUMA 200L Fanuca 21t, Clamp/Unclamp
    Jan 2013
    37
    Hello,
    I am having problems with the M69 and M68 codes.... I am trying to unclamp (M69), use a bar puller, then clamp (M68). As soon as I unclamp I get an alarm for ( 2060 Chuck UNCLAMP Status ). I even tried it in MDI with same results. Now the machine did come with a barfeeder that I do not have hooked up. It has a jumper wire where the barfeeder plug goes into the machine.... Is there an parameter thats turned on to give this alarm because of the barfeeder not hooked up ? If so any Ideas ?
    Thanks !!
    Dec 2012
    395
    Hello,
    Don't you have a "Spindle Interlock" M-code for your problem, maybe M31/M41? It could also be a parameter issue. I assume you have live-tools and you want to use G98 (mm/min) instead of G00 wich is to fast for bar-pull.
    Look at your manuals if there is a proper code.
    Heavy_Metal
    The Netherlands.
    Jan 2013
    37
    Thanks for the input ! Turns out I needed the door shut and in auto mode, NO single block. It will alarm out even if door is closed and in single block mode. Now it works great, Thanks !
  1. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  2. Unclamp/Clamp on yasnac lx3
    By Delw in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2018, 11:22 AM
  3. Daewoo PUMA 200L Fanuca 21t
    By GTMondock in forum Daewoo/Doosan
    Last Post: 02-12-2013, 10:42 PM
  4. Please help with Daewoo DMV 3016 Spindle clamp/unclamp alarm.
    By nickhough in forum MetalWork Discussion
    Last Post: 05-09-2011, 04:39 PM
  5. Clamp Unclamp Problem VMC
    By 24kilo in forum Fanuc
    Last Post: 01-18-2010, 11:44 PM
