603,855 active members*
3,592 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo puma 6s Parameters needed
    Sep 2020
    3
    I have a Daewoo 6s lathe the battery died so I lost everything.
    I do have a 14 page printout of settings to use. I have input lines 001 too 8000+ manualy typed in.
    I have not had any luck in getting machine to go past start up info screen. I get no alarms up so can't really look up more info
    There is a few pages with I think 9000+ number lines of code that I can't find where to input the data to..
    From what I have been reading u can upload parameters from a pc I have old pc with rs232 port etc
    Where do I go from here? Any help on where to input the last 6 pages of code in or a file I could try to load in would be very helpful and much appreciated
    I did post a similar question in fanuc topic but I should have posted here sorry.
    Jul 2005
    380
    Re: Daewoo puma 6s Parameters needed
    Some parameters can be manually typed in. Some can be loaded thru tape reader (not recommended) or RS-232.
    Contact your Doosan distributor. Doosan keeps a record of machine parameters and would be able to help.
    Also, contact Darryl Hardt in Doosan Service - tell him I sent you.
    Sep 2020
    3
    So i got hold of the Australian branch as this is where the machine was sold (HARE & FORBES). No luck
    the best he could do was a paper copy of a machine from that range. That is no use to me as i have a paper copy of my exact machine parameters but can only input 6 pages or so of data out of 14 pages.
    Is there a way to write your own parameter file from the 14 pages of data i have?
  1. Replies: 2
    Last Post: 05-07-2023, 02:06 AM
  2. Need help, Daewoo PUMA 6 s missing parameters
    By RTS_Norway in forum Daewoo/Doosan
    Last Post: 11-04-2019, 03:33 AM
  3. daewoo puma 10s parameters list
    By azizcom83 in forum Daewoo/Doosan
    Last Post: 04-11-2016, 01:22 PM
  4. Need Daewoo Puma 230MS parameters
    By fm.ind in forum Daewoo/Doosan
    Last Post: 10-17-2012, 12:12 AM
