603,310 active members*
2,375 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 8HC-3A Tailstock question
Results 1 to 8 of 8
    Jan 2008
    78
    Is there a mechanism or procedure (other than beating the live center with a hammer) to remove a live center from the tailstock quill?
    BTW, we do not have manuals for this model.
    Cheers,
    Steve E
    Dec 2015
    214
    Re: Daewoo Puma 8HC-3A Tailstock question
    which controller model with machine fanuc or mistubushi???
    Jan 2008
    78
    Quote Originally Posted by phucrobusl View Post
    The control is Fanuc 15TF, & we do not use the conversational language feature of the control. We only use straight G-code.
    Cheers,
    Steve E
    Feb 2013
    796
    Without the exact serial number this is the best guess on the parts section...
    Attached Files Attached Files
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jan 2008
    78
    I figured out the technique. I use the locking nut (item #44 on drawing) to force out the live center. Sorta like a collet in reverse.
    Cheers,
    Steve E
    May 2009
    4
    thanks
    Quote Originally Posted by dhardt View Post
    Amigo buen día, quisiera saber si usted tiene algún respaldo backup para mí maquina Daewoo Puma 230 control Fanuc 21i-T año de fabricación 2000.
    Se daño nuestro controlador y tenemos problemas porque no tenemos el respaldo de nuestra máquina gracias.
    Jan 2025
    Hey, i have the same problem but on a doosan puma 2600y, did you tighten the nut to get your centre out or loosen it, I've tried loosening mine but centre won't budge at all
  1. Daewoo A-20 tailstock broken
    By RG NDT in forum Daewoo/Doosan
    Last Post: 01-30-2013, 11:47 PM
  2. Puma 2500y needs help with tailstock
    By phx in forum Daewoo/Doosan
    Last Post: 04-14-2012, 05:59 AM
  3. Daewoo puma 8s
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-14-2010, 07:58 AM
  4. can the tailstock be programmed on Daewoo puma 230m
    By Bigbill in forum Daewoo/Doosan
    Last Post: 05-25-2007, 01:38 PM
