we have old Datron CAT3D M3 machine that is run with DOS based software and works with "mcr" code.
The problem is that it doesn't recognize my G02 and G03 codes which are probably recognized in newer versions of software (I see in manual that it should). It should in newer versions also have "iso" converter.
Original command that mcr uses is "circle" but I don't know how to convert it to this command.
Is there someone that uses Datron from DOS? How do you make code for it?
Any help or contact could help me.
Datron service doesn't support DOS versions and don't have backup of it.
Tomislav
