587,560 active members*
3,485 visitors online*
Page 6 of 6 456
Results 101 to 103 of 103
  1. #101
    Oct 2009
    838
    Re: David A's Benchtop CNC Version 2
    VACUUM HOLDING SET INSTALLATION:
    Machine bed already contains all the channels and holes for
    vacuum holding so just a manifold needs to be installed:
    Attachment 467216
    Manifold will be installed in this area under the machine bed:
    Attachment 467218
    Screw on the manifold to the underside:
    Attachment 467220
    Attach the standard Schedule 40 elbow to the manifold.
    It can be oriented in any direction to match the vacuum pump location:
    Attachment 467222
    Overall layout of the vacuum holding system:
Name:	EXP Vac 5 color.jpg
    Vacuum holding set installation is finished.
    A single piece of 1/4" MDF sheet on top of the machine bed to be provided by customer.
  2. #102
    Oct 2009
    838
    bryggacnc website has been updated with the vacuum holding set page.
  3. #103
    Oct 2009
    838
    Hi guys,
    I will be out of the country for business for a while and won't be able to work on the machine during that time.
    I will be following CNC Zone on the computer, though.
    David
Page 6 of 6 456
  1. David Rigotti - Hobby CNC Plans
    By KeithSloan in forum DIY CNC Router Table Machines
    Last Post: 03-30-2020, 01:51 PM
  2. David A's New 2x3 Bench Top CNC
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 08-18-2019, 01:47 AM
  3. Replies: 1
    Last Post: 03-29-2017, 03:18 PM
  4. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  5. I built My CNC From David Steels Plans Now I need Feedrate help please
    By tager_rot in forum DIY CNC Router Table Machines
    Last Post: 09-09-2007, 07:52 PM
