588,510 active members*
4,772 visitors online*
Results 1 to 5 of 5
    Oct 2006
    11
    David Laser Scanner
    Check this out at:
    http://www.cs.tu-bs.de/rob/david.html
    Dec 2006
    25
    David
    You beat me to it.
    Still, Awesome piece of software for anybody doing 3d work.
    Timo Guest
    You can find the latest version of the 3D laser scanner software at
    www.david-laserscanner.com
    Jan 2006
    12
    I had played with that a few months ago, it's pretty neat but I couldn't get it to work very well. I think my laser was bad, used a cheap laster leveler. I also had problems with getting the right lighting.
    Although I think with a little bit of a $$ investment on the proper tools and work area it would work really well.
    Sep 2006
    37
    Has anyone tried using a slide projector instead of a laser? It's mentioned in the the 3D for crazies thread, but I don't think anyone tried. It was suggested to use two pieces of electrical tape on a slide to make a slit and use the resulting white line as a "laser". I might try this if I can find a slide projector.
    Also it looks like the camera used can have a big impact on the resolution of the digitized image.
    Steve
