HuguesP and mactec54, thanks for your encouragements.
Now, the machine needs to be leveled,
not only for actual cutting but also for
the cutting coolant system to work.
Poor a bit of colored water on the bed.
Also a good test for any leakage:
Attachment 414108
You want the water to ever so slightly
and evenly to collect along the line of
the drain slots:
The machine weighs about 330 pounds.
Attachment 414114
It is a bit tough to turn the 1" bolts of the
feet with that weight on them. A car
jack makes it easy to fine tune the level
of the machine without hurting my back:
Looking forward to the first project!!
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
Hah, wmgeorge, me too, believe me.
Still some ways to go though......
I will need all the expertise I can get
once I get to the electrical part.
Cutting coolant pump in action.
It's got way more flow than I was thinking.
Anybody has an idea for a simple flow restrictor
for 3/8 OD tubing?
Maybe need to put some flow restrictor in line:
https://youtu.be/ZA0YPjmymPo
And here are the spouts discharging.
I need to design better spouts though,
splattering all over the tray. Needs short
pieces of tubing instead of a slot:
https://youtu.be/gHQY4D2CxuU
The cutting coolant system works better
than I expected but needs a bit of fine
tuning.
restrictor for 3/8 OD tubing?
Do these revisions ever end?
Move on to the next component.
THE VACUUM SYSTEM:
The table is made up of 1" HDPE strips:
Attachment 414166
The aluminum sheet bed has corresponding
transfer holes for the vacuum system:
Attachment 414168
The HDPE has vacuum holes on top
throughout on a 1-3/8 grid:
If your just needing to cut aluminum than a mister directly on the tool would work fine. Of you can flood coolant. In either case you need a add a small ball valve for control.
Close-up of the vacuum holes:
Attachment 414172
There are channels on the bottom of
those HDPE strips, carrying the
vacuum to each hole:
Attachment 414174
There is a simple manifold at the bottom
of the machine bed, connecting all
vacuum channels on top of the HDPE table:
Attachment 414178
Attachment 414180
Ready for assembly to the bottom:
Attachment 414182
Align the manifold to the bottom of
the bed and tighten it from the top:
Attachment 414184
Manifold installed to the bottom:
Attachment 414186
Choose the size of your PVC fitting to
match the size of your vacuum hose:
Vacuum system finished.
Of course, the PVC fitting can be rotated in any
direction you want. I oriented it to the front:
Attachment 414190
Attachment 414192
Thanks mactec54, I need to play around with it a bit.
Shop vac hose and adaptor hooked
up to the vacuum system:
Attachment 414270
Later, there will be a single piece
4MM or 6MM MDF cover over the
table which I don't have at this moment.
Here I am trying it out with a 13x18
plastic pouch. Remaining holes are
covered with sheets of paper:
Here is the test.
You need about 9-10 pounds of pull to make the pouch move.
The single point pull with the scale makes the pouch
crease up before letting go. A full width, even pull would
probably show somewhat higher values:
https://youtu.be/m4Y1mKaiFt0
