588,209 active members*
4,673 visitors online*
Page 8 of 43 67891018
Results 141 to 160 of 848
  1. #141
    Sep 2005
    1740
    Re: David A's New 2x3 Bench Top CNC
    I have a Shop Vac like that maybe next size up, 2 inch hose and it worked fine on a 2+2 foot vac taable.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  2. #142
    Aug 2018
    621
    Just had to comment on your machine, very nice build!! And when you get to the electronics, do yourself a favor and check out Centroid Acorn if you haven't yet. They have a great forum and a lot of very smart guys who will help you out with the electronics.
    Dan
  3. #143
    Oct 2009
    867
    Quote Originally Posted by wmgeorge View Post
    Thanks for the info, wmgeorge.
    I think 9-10 pounds of horizontal holding
    force is fine for fabric/leather/paper cuts.
    Maybe even PCB boards.
    I think, you are right, 2x2 is probably
    the size limit for a shop vac type. Would
    be interesting to see if a vacuum blower
    would do better but I am happy with the
    results of the vacuum test for now.
  4. #144
    Oct 2009
    867
    Quote Originally Posted by Ntl View Post
    Dan
    Dan, thank you.
    Unfortunately, I already got a UC100 and a C11G for the machine.
    And with all the help I got here from our experts, I feel comfortable
    about keeping the electrons in check here as well.
    Hopefully, next time. I have a tendency to keep building machines.
    Maybe there is medical term for my condition.
  5. #145
    Aug 2018
    621
    I couldn't tell from the pictures, how are you driving the x and y axis ballscrews?
  6. #146
    Oct 2009
    867
    Dan,
    The ball screw drive installation will be
    shown pretty soon as I kind of laid out a
    sequence in my mind for this build.
  7. #147
    Oct 2009
    867
    Next step is installing the shelf.
    The Laptop Shelf:
    It is pretty straight forward.
    Two side plates:
    Attachment 414302
    Attach the slides to the side plates.
    All holes are pre-drilled. Slides
    are 22" long and have end stops:
    Attachment 414304
    Install the side plates to the stringers:
    Attachment 414306
  8. #148
    Oct 2009
    867
    Side plates installed
    and slides pulled out:
    Attachment 414308
    The shelf is 20x28:
    Attachment 414310
    Shelf installed:
Name:	6 IMG_7185.jpg
  9. #149
    Oct 2009
    867
    Plenty of space for
    15 or 17 laptops and peripherals:
    Attachment 414314
    Working position:
    Attachment 414316
    Enough clearance for a full size mouse:
Name:	9 IMG_7187.jpg
  10. #150
    Sep 2005
    1740
    Quote Originally Posted by davida1234 View Post
    Dan, thank you.
    You must be a new retiree. My first year of retirement I built a backhoe attachment for my old John Deere tractor. Then proceeded to use it down at the Lake to dig in our sewer lines, electrical and build a retaining wall.
  11. #151
    Oct 2009
    867
    Shelf tucked in:
    Attachment 414330
    Works really nice and the end
    stops keep it in place in and out.
    SPOIL BOARDS:
    As mentioned, the table consists
    of 1" HDPE strips:
    Attachment 414332
    You install different spoil board strips
    on top depending on your cut:
    Attachment 414334
    They are all mounted from the top to the
    HDPE table with 5/16 pan head bolts:
    Attachment 414336
  12. #152
    Oct 2009
    867
    For dry cuts, use MDF, birch ply
    or HDPE spoil board strips:
    Attachment 414338
    For wet cuts, use HDPE strips:
    Attachment 414340
    For vacuum, use the single piece,
    full size 4MM MDF covering the
    whole table. I didn't cut it yet.
    For now, I am installing 1/2" HDPE
    spoil boards as it is the most
    versatile material. I decided to have
    some fun and use red ones:
    Attachment 414342
  13. #153
    Oct 2009
    867
    Just a small tidbit.
    I use 5/8 backer rods for all open slots
    on the extrusions. Keeps dust and debris
    out of the slots better than the commercial
    covers.The McMaster-Carr ones are firmer
    and work better than the HD ones:
    Attachment 414344
    Attachment 414346
  14. #154
    Oct 2009
    867
    Hah, I wish I could afford to be a retiree
    and have my beer on a beach in Hawaii.
  15. #155
    Oct 2009
    867
    Now comes the biggest item.
    ELECTRICAL INSTALLATION:
    First the electrical box.
    The electrical box will be attached to the
    shear panel of the side frame. Bolts
    will use sealing washers to protect the
    outside of the panel from cutting coolant:
    Attachment 414356
    The power supply is an AnTek 800 Watt
    toroidal. 75V @ 10.5A with 5V and 12V 1A
    modules, sized for the servos I will be using:
    Attachment 414358
    Install power supply to the shear panel:
Name:	3 IMG_5961.jpg
Name:	4 IMG_5924.jpg
  16. #156
    Oct 2009
    867
    Power supply installed:
    Attachment 414372
    Next, install the first frame of
    the E-box to the shear panel:
    Attachment 414374
Name:	7 IMG_5964.jpg
  17. #157
    Oct 2009
    867
    Install the second frame of the E-box:
    Attachment 414382
    I will be using the C11G BoB from
    cnc4pc for this machine. Pretty
    basic BoB but has spindle control
    and the I/O's I will need:
    Attachment 414384
    Install the UC100 motion controller
    to the C11G . Install the assembly
    to the E-box:
Name:	10 IMG_6843.jpg
  18. #158
    Aug 2018
    621
    I was just curious are you routing out all the components for the build, or do you have a mill that you're using?
    Dan
  19. #159
    Sep 2005
    1740
    Dan
    I am wondering the same thing, I was going to guess water Jet. At least on part of it anyway.
  20. #160
    Oct 2009
    867
    I am routing out everything.
  1. Pro- Bench Lathe & Pro Bench Mill Drill
    By tw-bob in forum News Announcements
    Last Post: 06-06-2014, 02:32 AM
  2. CNC bench lathe or other small bench lathes
    By Scootworks in forum Turning Machines
    Last Post: 08-20-2011, 06:36 AM
  3. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  4. David
    By [email protected] in forum Fanuc
    Last Post: 12-11-2009, 08:56 PM
