588,208 active members*
4,160 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > DC Gear motor and power off brake(on the load side not on motor)
    Oct 2012
    21
    Ok for example a dc gear motor with a ratio of 168:1 and a peak torque of 8332oz in. The load is 4383.9oz in. Can a power off brake be applied to the load side and not the motor itself before the gear. How much stopping force wold be needed.Would it need to match the exact load (4383.9)?
    May 2013
    480
    Re: DC Gear motor and power off brake(on the load side not on motor)
    need more information.
    what is the load's intertia? i'm not sure if you gave the load, or the inertia.
    is the gear box at risk of being destroyed beyond 8300 oz-in torque? or is that that torque a function of the motor burning out due to over current.
  1. G540 Rev.5 mod to use motor-side resistors
    By Gall in forum Gecko Drives
    Last Post: 06-20-2013, 03:17 PM
  2. Mounting motor off the side of head..
    By TiagoSantos in forum Benchtop Machines
    Last Post: 11-22-2012, 03:49 PM
  3. disassemble brake on a2/3000 motor ?
    By jmelson in forum Fanuc
    Last Post: 07-25-2011, 04:02 AM
  4. Z AXIS MOTOR WITH BRAKE
    By Russ Shugg in forum Servo Drives
    Last Post: 10-26-2009, 08:45 PM
  5. Stepper Motor Belt Drive Side Load Question
    By harryn in forum Stepper Motors / Drives
    Last Post: 08-07-2007, 11:23 PM
