What are the complete accessories of DC Servo motor.
E.g DC servo motor, Encoder.........????
what else i need to make it operational.
You need also a breakout-board (with optokopplers) and a driver untit for the motor. Thats it.
You also need an appropriate power supply if it is not built into the drive.
Typically for a separate DC supply, the voltage should be at least 10% above the rated motor voltage.
The drive should accommodate the type of command signal, e.g. step/dir, ±10vdc analogue etc.
Al.
Albert E.
