Hi!
I have a HUGE problem with a Leblond RMC55 with a Fanuc 0M controller.
I left the machine a few days ago, jogged the machine, turned the power off to the drives with the emergency stop button. Came in last night, the screen was working, turned the drives on with the emergency button, the machine didn&%****17;t power up the drives, there was no fault codes on the screen nothing! So I turned the machine completely off, then turned it back on again, but it didn&%****17;t power up. I can hear the relay in the cabinet when I turn the machine on and off from the controller, but the screen doesn&%****17;t power up, and the drives do not power up.
On the power transformer, I appear to have the correct voltage, at all the taps, except the 200V tap is only reading 120V
The power unit appears to be OK, the voltages all check out, and the green light is ON.
On the drive board the DC voltages all read about 0.4V instead of 5VDC and 15VDC. So it doesn&%****17;t appear to be getting power.
I can&%****17;t find a fuse anywhere, does anybody have any suggestions as to what it could be?
It looks like it might be the transformer, except the power unit is OK, and the DC voltages are correct, Thanks for any help.
Dave
