588,444 active members*
5,262 visitors online*
Results 1 to 4 of 4
    Jun 2005
    24
    Dead LPT port?
    I've been playing around whit the MACH3 software a bit, but when I went about hooking up a cable to my LPT1 port, I doesn't seem to get any sinals, either input nor output.
    I haven't connected any machinery yet. was just trying to get a view of the pulsetrain on my scope.
    The (working) scope just shows me zero volts on all pins, no matter what I do.
    I then tried to set up some inputs in MACH3, but the indicators didn't light up no matter what I did.
    I thought that even if the pins are "NC", the internal circuits in the LPT would pull the line to +5v and show up as "Active" when pulled to GND. That didn't work.
    Also tried setting "Active low" to zero, but manually pulling the pin to +5v didn't change anything.
    I'm starting to worry about the health of my LPT port.
    Is there a way of testing the LPT port (wich I haven't used for years) whitout actually hooking up a printer of sorts (wich I don't even have)?
    If my LPT port are really dead. Could I use one of these USB->LPT adaptors whit MACH3, or would that just make a big mess?
    Mar 2005
    361
    did you check to make sure it had not been disabled in set up? Or had come
    loose ?
    Mike Laws
    Jun 2003
    866
    Do you have a breakout board attached? Is the port enabled in the bios? If you were just excercising the port using Mach, I suppose it's possible that it's not finding it. I'm just throwing out ideas, so don't be offended. I do a lot of work with data acquisition hardware and computers, and I find that such hardware often does nothing if any little thing is wrong.
    You can't use a USB dongle, the timing will not be right. The way I look at it, a PCI printer port board is a cheap investment even on a cheap motherboard. It's a lot more work replacing a smoked mobo than a smoked pci board.
    Jun 2005
    24
    Well...
    My LPT port is working like a charm. The problem was me. Not the hardware.
    No.. It wasn't disabled in BIOS or anything like that.
    In my enthusiasm and typical hurry, I ignored the warning that I might would like to reboot after installing MACH3.
    I tried rebooting several times after I found out it didn't work, but the harm was already done.
    The solution?
    Run "C:\Mach3\OCXDriverTest.exe" once and reboot.
    After that, everything was in working order.
    The downside is that I realize my stepper driver design need alot more work.
    Aprechiate the input.
