603,409 active members*
2,891 visitors online*
    May 2005
    1662
    Dealing with backlash
    Recently bought a X2 mini mill with plans to convert to cnc. A Xylotex kit seems the simple control solution. The confusing part is the mechanical bits. Cncfusion offers a rolled ballscrew kit which sounds like a simple fit. Not sure if it will be accurate enough for interpolated paths? From the information available it seems the accuracy of the screws provided can be a bit "luck of the draw" .
    This post from the emc mailing lists is a bit worrying
    http://sourceforge.net/mailarchive/m...st.localdomain
    Is backlash in Mach3 taken up more gradually? Some Mach3 users appear to be getting away with backlash well in excess of a thou or two..
    One solution that comes to mind is going with the cncfusion kit and replacing the cheap ballscrews with better ones when available. Ground ones from ebay with a little luck.
    Anyway, anyone here doing ok with larger backlash using emc ? My background with cnc is in a commercial enviroment so not use to thinking about backlash much.
    Dec 2003
    24260
    You could keep an eye out for these to come up again, I suspect there will be more.
    http://cnczone.com/forums/showthread...ighlight=hiwin
    I have tried nook rolled and was not very impressed with the quality of the one's I got.
    The one's this guy is selling is the next best thing to precision ground in my opinion, which usually cost a fortune.
    Watch out for rolled that do not have a pre-loaded ballnut.
    Al.
    Albert E.
    Feb 2007
    532
    My current setup has .34mm (13.3 thou) backlash on the Y, and as it's relatively stiff it works fine... I'm just cutting wood and plastic on a router though, not metal.
    If I climb cut across the 'Y' it will move a bit due to the backlash, but if I conventional cut it holds fine against the backlash, or at least seems to.. It's definately 10x worse if I remove the backlash settings from EMC..
    You can set the rate the backlash step is taken up, although I've just left mine at the default that was in stepper_mm.ini.
    Cheers, Me.
  1. Backlash
    By N4NV in forum Linear and Rotary Motion
    Last Post: 03-29-2007, 02:37 AM
  2. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
  3. Backlash
    By PIngels in forum Uncategorised MetalWorking Machines
    Last Post: 07-30-2006, 10:59 AM
  4. Re backlash
    By phil spanner in forum Mechanical Calculations/Engineering Design
    Last Post: 09-08-2005, 04:57 PM
  5. What is backlash ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 08-17-2004, 01:27 AM
