603,348 active members*
3,737 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Dealings with these ? CNC Router company - Redsail / Hflaser
Results 1 to 4 of 4
    Dec 2012
    Afternoon folks,
    In my quest to find my self a decent CNC Router to purchase from a reliable/reputable company i have come across 'Redsail' or their website Laser Engraver - Engraving Laser Cutting Machine, Vinyl cutter, Cutting plotter by Redsail
    They have offered me a competative quotation on thier 4' x 8' CNC Router which sums up as below:
    Gantry Height: 200mm
    X, Y ,Z Guide: Rack and Pinion ,Gear driver, Square linear guide way
    Drive type: Micro-Step Stepper Motor
    Spindle: 3.0KW high speed (water cooling)
    Max Moving Speed: 35000 mm/min
    Max Cutting Speed: 25000 mm/min
    Resolution: 0.025mm
    ACCURACY:0.01MM
    Interface: DSP handle (read USB memory directly)
    Command code: HPGL, G-code
    Spindle tools: ф3.175, ф6, ф12.7
    Power: AC220V±10% / 50~60Hz
    Machine dimension: 3200*2000*1600(mm)
    Id like to know how the above sums up to other Chinese based CNC Routers and if anybody else has had dealings with this company ???
    Thank you
    Feb 2009
    6028
    Have a re branded redsail cutter plotter. Works fine, built pretty well. Can't complain for the price.
    Jun 2011
    279
    Price
    What price did they quote you? I should have mentioned the salecnc machine z height is wrong on their site. It is 200mm like the big machines in that class.
    Chris
    Aug 2012
    yes, usually the working size of 4*8 cnc router is 1300mm*2500mm*200mm.
    It is much better if the square rail, ball screw are imported.
    The spindle is optional, you can chose air-cooling or water-cooling.
    Motor: stepper or servo. Servo is better: high stability and more powerful.
  1. First CNC router, for snowboard company
    By Rswilliams13 in forum DIY CNC Router Table Machines
    Last Post: 12-09-2011, 07:14 PM
  2. Redsail Laser Help...
    By ivirscar in forum Redsail Laser
    Last Post: 11-25-2011, 09:31 AM
  3. purchasing the cnc router machine from Kemingweiye company (Fanch)
    By aseman in forum Want To Buy...Need help!
    Last Post: 06-21-2011, 10:51 AM
  4. we supply cnc router with branch company abroad
    By danielhao in forum News Announcements
    Last Post: 07-22-2009, 10:23 AM
  5. What is the truth about iehk.net, hflaser.com, hxlaser.com, etc?
    By Furthest in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2007, 04:59 AM
