586,058 active members*
3,768 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Deckel maho 60T TNC 426/430 magasin problem
    hello i have problem with Deckel Maho 60T with magasin TNC 426/430
    machine not changing tools with magasin but only manual changing
    please help how to activate automatic changing tools from magasin
    for the moment is like this MDI tool call 1 Z and Y axis go to door and i have to open door change manual tool and close door
    Oct 2018
    11
    Re: Deckel maho 60T TNC 426/430 magasin problem
    Hi, I think you need to check first your tool table and then the pocket table.
    If a tool is in the pocket table in position 1-20 then your machine should then go to the magazine.
    If the tool does not appear in the pocket table then the machine assumes it is a manually loaded tool.
    Hope this helps
  1. deckel maho dmu 50 t
    By gunz in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2021, 01:54 PM
  2. Deckel Maho Heidenhain 426PB parameter entry problem
    By hell_pk in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-13-2017, 07:29 AM
  3. Deckel Maho DMU 50 VL
    By waltteris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-13-2016, 09:32 PM
  4. chiller problem Deckel Maho 60 HSC
    By aeriz12 in forum Okuma
    Last Post: 10-11-2016, 02:50 AM
  5. Deckel Maho 600E - Axis switch problem!
    By SorenF in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-25-2016, 08:00 PM
